关于BiSeNetV2模型的支持
Viewed 71
2.9是不是不支持BiSeNetV2这个模型,我生成ONNX转换成Kmodel,发现转换失败呢
报什么错了,转换脚本怎么写的?
代码发上去了,帮忙看一下
#!/usr/bin/env python3
ONNX to K230 kmodel Converter
用于将 ONNX 模型转换为 K230 可执行的 kmodel 文件
import argparse
import numpy as np
import onnx
import nncase
def parse_args():
    parser = argparse.ArgumentParser(description='Convert ONNX to K230 kmodel')
    parser.add_argument('--model', type=str, required=True, help='Path to ONNX model file')
    parser.add_argument('--output', type=str, required=True, help='Path to output kmodel file')
    parser.add_argument('--input_shape', type=str, default='1,3,640,640',
                        help='Input shape in format: batch,channels,height,width')
    parser.add_argument('--input_type', type=str, default='float32',
                        choices=['float32', 'uint8'], help='Input data type')
    parser.add_argument('--quantize', action='store_true', help='Enable quantization')
    parser.add_argument('--calibrate_method', type=str, default='NoClip',
                        choices=['NoClip', 'Kld'], help='Calibration method')
    parser.add_argument('--samples', type=int, default=10, help='Number of calibration samples')
    return parser.parse_args()
def parse_input_shape(shape_str):
    """Parse input shape string like '1,3,640,640' to list"""
    return [int(x) for x in shape_str.split(',')]
def generate_calibration_data(shape, samples=10):
    """Generate random calibration data for quantization"""
    data = []
    for _ in range(samples):
        sample = np.random.randint(0, 256, shape).astype(np.uint8)
        data.append([sample])
    return np.array(data)
def main():
    args = parse_args()
    print("=" * 60)
    print("ONNX to K230 kmodel Converter")
    print("=" * 60)
    print(f"Input model: {args.model}")
    print(f"Output model: {args.output}")
    print(f"Input shape: {args.input_shape}")
    print(f"Input type: {args.input_type}")
    print(f"Quantization: {args.quantize}")
    print("=" * 60)
    # 1. Check input file
    if not os.path.exists(args.model):
        print(f"Error: ONNX file not found: {args.model}")
        sys.exit(1)
    # 2. Load and verify ONNX model
    print("\n[1/5] Loading ONNX model...")
        onnx_model = onnx.load(args.model)
        onnx.checker.check_model(onnx_model)
        print(f"      ONNX model loaded successfully")
        print(f"      Opset version: {onnx_model.opset_import[0].version}")
        print(f"      Error: {e}")
        sys.exit(1)
    # 3. Parse input shape
    input_shape = parse_input_shape(args.input_shape)
    print(f"\n[2/5] Input configuration:")
    print(f"      Shape: {input_shape}")
    print(f"      Type: {args.input_type}")
    # 4. Setup compile options
    print("\n[3/5] Setting up compile options...")
    compile_options.target = "k230"
    compile_options.input_shape = [input_shape]
    compile_options.input_type = args.input_type
    compile_options.input_layout = "NCHW"
    if args.input_type == 'uint8':
        compile_options.input_range = [0, 1]
        compile_options.std = [1, 1, 1]
    print(f"      Target: {compile_options.target}")
    print(f"      Input shape: {compile_options.input_shape}")
    print(f"      Input type: {compile_options.input_type}")
    # 5. Create compiler and import ONNX
    print("\n[4/5] Compiling model...")
        with open(args.model, 'rb') as f:
            model_content = f.read()
        print("      ONNX import successful")
        print("\n=== DEBUG INFO ===")
        print(f"ONNX file size: {os.path.getsize(args.model)} bytes")
        print(f"Input shape: {input_shape}")
        print("=================")
        sys.exit(1)
    # 6. Quantization (if enabled)
    if args.quantize:
        print("\n[5/6] Applying quantization...")
        ptq_options.samples_count = args.samples
        ptq_options.calibrate_method = args.calibrate_method
        ptq_options.w_quant_type = 'uint8'
        ptq_options.quant_type = 'uint8'
        # Generate calibration data
        calib_shape = input_shape
        calib_data = generate_calibration_data(calib_shape, args.samples)
        compiler.use_ptq(ptq_options)
        print(f"      Method: {args.calibrate_method}")
        print(f"      Samples: {args.samples}")
    # 7. Compile
    print("\n[6/6] Compiling to kmodel...")
        compiler.compile()
        # Save to file
        os.makedirs(os.path.dirname(args.output) or '.', exist_ok=True)
        with open(args.output, 'wb') as f:
            f.write(kmodel)
        size_kb = os.path.getsize(args.output) / 1024
        print(f"      Compilation successful!")
        print(f"      Output file: {args.output}")
        print(f"      File size: {size_kb:.2f} KB")
        sys.exit(1)
    print("\n" + "=" * 60)
    print("Conversion completed successfully!")
    print("=" * 60)
    main()
报什么错了?
错误通过回答发上来了
我想问一下,你们有看到我的问题吗,有帮忙在检查问题吗
Opset version: 18
Shape: [1, 3, 640, 640]
Type: float32
Target: k230
Input shape: [[1, 3, 640, 640]]
Input type: float32
Unhandled exception. System.ArgumentException: The value cannot be an empty string. (Parameter 'path')
at System.ArgumentException.ThrowNullOrEmptyException(String argument, String paramName)
at System.IO.Directory.GetParent(String path)
at Nncase.Importer.OnnxImporter.GetTensor(TensorProto tensor)
at Nncase.Importer.OnnxImporter.GetInputExpr(NodeProto n, Int32 index)
at Nncase.Importer.OnnxImporter.GetInputExprs(NodeProto n, Int32 index0, Int32 index1)
at Nncase.Importer.OnnxImporter.VisitConv2D(NodeProto& op)
at Nncase.Importer.OnnxImporter.Visit(NodeProto op)
at Nncase.Importer.OnnxImporter.ConvertOp()
at Nncase.BaseImporter.Import()
at Nncase.Importers.ImportOnnx(Stream onnx, CompileSession compileSession)
at Nncase.Compiler.Interop.CApi.CompilerImportOnnxModule(IntPtr compilerHandle, IntPtr streamHandle)
