K230 跑yolo11时更改摄像头报错
Viewed 87
File "", line 79, in
File "media/sensor.py", line 1, in run
RuntimeError: sensor(0) run error, vicap init failed(-1)
warning: sensor not call run()
sensor1 = Sensor(id=1, fps=30)
sensor1.reset()
sensor1.set_framesize(width=1280, height=720) # 硬件分辨率
# 初始化 Pipeline 和 YOLO
pl = PipeLine(rgb888p_size=rgb888p_size, display_mode=display_mode,display_size=display_size)
pl.create(sensor = sensor1,to_ide=True)
可以烧录新的固件:https://kendryte-download.canaan-creative.com/developer/releases/canmv_k230_micropython/daily_build/
现在支持直接在pl.create(sensor_id=1)传入sensor_id修改摄像头
