使用rgb888_find_rectangle_with_corners识别矩形时只能识别到矩形框的外框,增加识别矩形的rgb888_find_rectangle函数,限制识别矩形框里的矩形,识别到外框时无法识别出矩形,只有识别到内框时才能识别出,要如何改才能识别出框内的矩形
import time, os, sys, gc
from machine import Pin
from media.sensor import * # 摄像头接口 / Camera interface
from media.display import * # 显示接口 / Display interface
from media.media import * # 媒体资源管理器 / Media manager
import _thread
import cv_lite # cv_lite扩展模块 / cv_lite extension (C bindings)
import ulab.numpy as np # MicroPython NumPy类库
image_shape = [480, 640] # 高 x 宽 / Height x Width
sensor = Sensor(id=2,width=1280,height=960,fps = 90)
sensor.set_framesize(width=image_shape[1], height=image_shape[0])
sensor.set_pixformat(Sensor.RGB888) # RGB888格式 / rgb888 format
Display.init(Display.ST7701, width=image_shape[1], height=image_shape[0],
to_ide=True, quality=50)
gain = k_sensor_gain()
gain.gain[0] =20
sensor.again(gain)
threshold = [26, 74, -29, 81, -67, 63]# 格式:[Rmin, Rmax, Gmin, Gmax, Bmin, Bmax]
min_area = 100 # 最小色块面积 / Minimum blob area
kernel_size = 1 # 腐蚀膨胀核大小(用于预处理)/ Kernel size for morphological ops
canny_thresh1 = 80 #50 # Canny 边缘检测低阈值 / Canny low threshold
canny_thresh2 = 200 #150 # Canny 边缘检测高阈值 / Canny high threshold
approx_epsilon = 0.02 # 0.01 # 多边形拟合精度比例(越小拟合越精确)/ Polygon approximation accuracy
area_min_ratio = 0.001 #0.0001 # 最小面积比例(相对于图像总面积)/ Min area ratio
max_angle_cos = 0.15 #0.3 # 最大角度余弦(越小越接近矩形)/ Max cosine of angle between edges
gaussian_blur_size = 5 # 高斯模糊核尺寸(奇数)/ Gaussian blur kernel siz
# 拍摄一帧图像 / Capture a frame
img = sensor.snapshot()
img_np = img.to_numpy_ref()
rects = cv_lite.rgb888_find_rectangles_with_corners(
image_shape, img_np,
canny_thresh1, canny_thresh2,
approx_epsilon,
area_min_ratio,
max_angle_cos,
gaussian_blur_size
# 遍历检测到的矩形并绘制矩形框和角点
for i in range(len(rects)):
r = rects[i]
# 四个角点坐标(从检测结果直接取出)
p1 = (r[4], r[5]) # 角点1
p2 = (r[6], r[7]) # 角点2
p3 = (r[8], r[9]) # 角点3
p4 = (r[10], r[11]) # 角点4
img.draw_line(p1[0], p1[1], p2[0], p2[1], color=(255,255,255), thickness=2)
img.draw_line(p2[0], p2[1], p3[0], p3[1], color=(255,255,255), thickness=2)
img.draw_line(p3[0], p3[1], p4[0], p4[1], color=(255,255,255), thickness=2)
img.draw_line(p4[0], p4[1], p1[0], p1[1], color=(255,255,255), thickness=2)
# 画角点
img.draw_cross(p1[0],p1[1],color=(255,255,255),size=5,thickness=2)
img.draw_cross(p2[0],p2[1],color=(255,255,255),size=5,thickness=2)
img.draw_cross(p3[0],p3[1],color=(255,255,255),size=5,thickness=2)
img.draw_cross(p4[0],p4[1],color=(255,255,255),size=5,thickness=2)
if rects:
rects_all = cv_lite.rgb888_find_rectangles(
approx_epsilon,
area_min_ratio,
max_angle_cos,
gaussian_blur_size
for big_rect in rects:
bx, by, bw, bh = big_rect[0:4]
for i in range(0, len(rects_all), 4):
x, y, w, h = rects_all[i:i+4]
if (bx < x < bx+bw) and (by < y < by+bh)and (w*h < bw*bh*0.9):
img.draw_rectangle(x, y, w, h, color=(255,0,0), thickness=2)
# 显示图像 / Show image
# 垃圾回收 & 输出帧率/ Garbage collect and print FPS
print("fps:", clock.fps())
亚博智能
