图像检测识别物体不画框
Viewed 35
训练的是图像检测,代码运行后可以正常实时拍摄画面也不报错,可是识别到目标物体后不画框也不标注
训练的是图像检测,代码运行后可以正常实时拍摄画面也不报错,可是识别到目标物体后不画框也不标注代码如下
# -*- coding: utf-8 -*-
import os, gc, sys, time
display_mode = "lcd"
rgb888p_size = [640, 480]
kmodel_path = root_path + deploy_conf["kmodel_path"]
labels = deploy_conf["categories"]
confidence_threshold = deploy_conf["confidence_threshold"]
model_input_size = deploy_conf["img_size"]
# 鲁棒性修改:确保 anchors 转换万无一失
anchors = []
        # 尝试展开成一维列表 [33, 52, 69, ...]
    except:
        # 如果报错,直接传入原始结构
inference_mode = "video"
debug_mode = 0
det_app = DetectionApp(inference_mode, kmodel_path, labels, model_input_size, anchors, model_type, confidence_threshold, nms_threshold, rgb888p_size, display_size, debug_mode=debug_mode)
det_app.config_preprocess()
            img = pl.get_frame()
            if img is None:
            if hasattr(pl, "osd_img") and pl.osd_img is not None:
                    pl.osd_img.clear()
                except:
                    pass
            res = det_app.run(img)
            # 重点观察这里!!
            if res:
                print("Detected successfully:", res)
                print("Nothing detected")
            det_app.draw_result(pl.osd_img, res)
            pl.show_image()
    print("User stop", e)
    print("Exception", e)
        det_app.deinit()
    except:
        pass
    except:
        pass
K230D
CanMV_K230D_ATK_DNK230D_micropython_v1.3-0-g8dd764f_nncase_v2.9.0.img
控制台显示上传中...
没识别到
就是没有识别到,可是我对准了我训练的物体了已经,它识别不出来
模型没训好或者阈值设置不合理
好的,我再重新训一下,谢谢
